ok i recently hooked up my xp1700+ and now overclocked it to 1800+(not unlocked)
and for now im just running out of a big rezivore with my pump in it so the lines go into the block and out of it back to the rez
i have a thermometer in my water and im going by my socket thermoresistor on my mobo,
but heres what i found....
rite now im running at 24c water and my cpu is 33c
and any other temps makes it differ 9c so its always 9c diffrent in temps at idle,
and at load i had my cpu at 36c and my water temps at 35c, so that means that at load my temps differ by 11c, for me thats pretty good! especially that im runnin out a of a 1gallon rez and its just cooling itself....
i did add some ice cubes in it and got it to around 15c and my cpu temp was 24c, but i forgot to check my load, because the ice melted to fast,
later im gonna take a airarator(one of them fishtank bublie things) and have it buble into the water and see if it cools good, and if it does, im gonna stick it in my window(outside around -10c) that would possibly get me great temps,
what do you think?
(sorry for the length)
what do you think?
