My WC Build
KCB064
Kailua, HI
I finally finished my first liquid cooled system, after about 3 months of building. Here is some of the hardware...
Antec 1200 case
Corsair 850W PSU
Asus P6t Deluxe v2
Intel Core i7-620
Corsair Dominator 6GB @ 1600Mhz
ATI 5850
OCZ Vertex 30GB SSD (2) in Raid0
Danger Den CPU Block
EK Dual bay reservoir
Swiftec MCP655 pump
Swiftec MCR220 radiator
Yate Loon Medium fans
I have the i7 running at 4.1 GHz at 1.3v. Idle temps 39-41C. Full prime 95 load after 20 min temps at 74-76C.
SSDs getting writes of 290MB/s and reads of 390MB/s.
Haven't played with the GPU much yet...
Thanks for checking it out and everyones help during the build!!
atomic ferret
I would replace the TDX block with something more recent. It's pretty outdated and you'll see a decrease in temps by switching to a Swiftech XT or HK 3.0.
K
KCB064
Kailua, HI
I'd love to put the new Heat Killer block on eventually. Just comes down to $$, I got the TDX for really cheap! It does a decent job for now... Temps should go down how much with better block? 5c?
Boulard83
:welcome:
Good job !
I agree with atomic about your block but yes ... its $$ for few °c
You have anything on the bottom/front of the case ? You could mount the rad inside the case this way. Quite EZ.
K
KCB064
Kailua, HI
I have the SSDs, a 1TB, and the pump there....i considered it, but it isnt a big deal to me to be outside...
deadlysyn
Folding Team Content Editor, Who Dolk'd my stars S
Stealing your megahurtz at night
I can completely relate to the money argument. My first set up had an Apogee GT and a heater core.
I can relate to the money reasoning as well. I have been piecing my loop together as I had the money to spare. The only parts that were bought new are about 5 fittings, and my tubing. Everything else was bought from the classies here, and I still spent around $300 for a CPU and GPU loop. I have been ordering what parts I could afford since September or October.
The loop looks pretty good, and if you are happy with your temps, I wouldn't change a thing.
