- Jul 22, 2010
Hello and let me thank you for your help in advanced for looking. My issue comes from a "new old stock" build.
Little background before specs.
My OC for the cpu is very stable and burnt in. With zero failures, the gains were tested and proven in games as far as FPS and general gameplay as well as timing program startups. My GPU is stock out of the box cooler and all for now. My fsb is OC to only 203 from 200 so very minamal. All my CPU OC is done by unlocked multiplier and my CPU does have a very nice cooler. Ram timings have been left stock do to many failed OCs on my part.
Issue:
When I play Wow or D3 my GPU setting must be on middle settings or else my FPS drop to under 30. Talking to about 8 other players with the same GPU and game latencies, they all have no problems running max setting and never dropping below 60 FPS when standing right by me ( 60 being the max with V sync). I dont know if its my gpu being kinda slow from the factory or maybe my overall rig. Ive tried to find my weak link, but no luck. Now most of the others running the same card are using a "newer" Cpu I-3 and I-5 some are using older amd without issues. I'm completely lost so here I am. Thanks again. Please let me know if I can provide any more info.
CPU Amd phnom 2 quad core 965 --- Oc 4.2
Gpu Gtx 550 TI oc edition
Ram corsair vengance 1600 ddr3 timings are 10-10-10-27-39 one stick 8g ---- was thinking about buying two fours for dual channel setup... Advice???
Power supply is 750 antec gaming PSU
Mother board is a gigabyte GA-970A-D3
Hope I got it all. Thanks
Issue:
