- Apr 9, 2001
- Lehigh Valley, PA
After reading the other X2 threads here and many others around the net, I thought for sure I would be able to get at least 2.6Ghz out of a 3800+ X2. Being that I phase-change, I thought 2.9-3Ghz would be achieveable.
The cpu I had in my box last was a 3500+ OC'd to 2.5Ghz. I ran that puppy for many months on end without so much as a hiccup.
The new X2 won't oc worth a §§§§ past 200mhz over stock speed (2.2Ghz). I am extremely disappointed in this chip. The highest vcore I have tried was 1.5v. At first I thought it was my bios. I'm using the Asus A8V Deluxe and flashed to the newest 1015 bios. I then found that 1013 is the first bios that supports X2, but there was some issues with it with E6 revision chips. So I reflased to 1014 (in between, LOL). Still can't get past 2.2Ghz.
When I initially dropped this cpu in the mobo, I kept all the same settings I was running my 3500+ at. The box wouldn't even post with the new cpu running the old 3500+ settings. I know for a fact my memory can handle 250Mhz at CAS2 2-2-5 1T (it has done so for the past 8 months).
My system is as follows:
AMD 3800+ X2
Asus A8V Deluxe bios 1014
1Gb Corsair XMS Pro CAS 2 2-2-5 1T
BFG 6800GT OC
Vapochill (non-lightspeed)
Here is the stepping of the cpu:
I've read here that 0526 or 0527 UPBW were excellent steppings in terms of overclocking. Mine appears to be a newer stepping and sucks-***. I am thinking my motherboard is a bit old and may be holding me back- but I don't want to upgrade to a PCI-e board just yet and I'll be hard pressed to find a decent AGP board these days.
Anyone have any reccomendations as how to clock this puppy higher?
This is my system:
AMD 3800+ X2
BFG 6800GT OC
This is my system:
