- Oct 6, 2002
- W. Lafayette, IN
It looks like my 2.0A died, but Im not too sure.
I had it running at 2540 at 1.62 v for 4 weeks, and all the sudden it started giving me fatal except errors, and I had to restart XP. It would no longer run stable in Prime 95. So I clocked it down to 2500, and it crashed in prime 95, had an error. Restarted, and I was playing a game, and all the sudden it had another fatal except error, and I restarted, and was greeted with a fatal exception error on booting Xp.
Tried to reinstall xp at 2000 mhz with a fresh partition, and it wont get past a certain point in XP, as it has a 386 fatal except error at the same point every time.
Not to mention I was taking the heat sink off, and the thermal paste basically glued the cpu to the heatsink, and the heatsink came out at some of an angle, so some of the pins bent.
I straighten the 3 or so pins, but now the cpu doesn't slide in on that corner.
Does this sound like N.S.D.S?
Indyxc
Indyxc
