n00b, is this all I need?
Quattro
Hello,
On your advice I have decided on a aquastealth system
I've been on their website and could you tell me the difference between the 3/8 ans 1/2 kits, apart from the price please?
Also would the 1/2 kit feature everything I need?
Thanks.
zip22
3/8" and 1/2" are the inner diameter of the tubing. 1/2" will offer less restriction. it should have everything you need.
Natalie
Westchester County
Also, with the 1/2, you may get better temps because more water flowing into the cpu block means more water absorbing the heat form the cpu block.
Quattro
Quattro
Yeah I realised that I am sure I have a small PSU in the loft somewhere.
iNSiGMA
Ohio, USA
No half the kit wouldn't feature everything you need, even if you got the full kit you would still need water, additives, and some other stuff they're fooling you into thinking comes included like a manual... ;)
