- Apr 1, 2002
Having recently bought my daughter a tablet for her birthday I thought I'd share my thoughts as well as the complete hardware specs.
Manufacturer's webpage: http://www.nabitablet.com/elev-8
I'll let you enjoy the manufacturer's pictures, as they are better then any I could take right now.
Hardware:
Inside the box you get a tablet, a red silicone bumper, a charging cable, and a 5V 2A USB charger.
The charging port on tablet is proprietary, supposedly to make it easier for kids to plug in. It looks a little like an HDMI connection:
(picture taken using the tablet itself)
If it was really supposed to be kid friendly it would help if it could be inserted either way up.
When holding it in landscape mode, the top of the tablet has the microphone hole, a Micro SDHC card slot, as well as the volume and power buttons. The right side houses the 3.5mm headphone jack and the power plug.
The silicone bumper is a little softer then I was expecting, but seems to provide good protection.
Neither my 7yr old or 3yr old have any trouble holding it or using it.
AIDA64 System report:
Manufacturer: FUHU
Model: NBX208HQCG
Brand: nabi
Board: msm8916
Device: NBX208HQCG
Hardware: qcom
Platform: msm8916
Product: nabiX2
Installed RAM: 1 GB
Total Memory: 930 MB
Available Memory: 328 MB
Internal Storage Total Space: 21.53 GB
Internal Storage Free Space: 15.23 GB
CPU is a Snapdragon 615 (which is actually MSM8939), which seems plenty fast for the target audience. Same as you'd find in a mid-range 2016 phone.
I feel like 2GB of RAM would have been nice. It doesn't have trouble running apps but gets a little slow when trying to multitask.
Comes with 32GB of internal storage, of which ~15GB is available immediately after setup. On the plus side, many apps are not system apps and can be uninstalled if desired - more on this later.
WiFi works well, as does the Bluetooth 4 (LE/Smart) and NFC.
AIDA64 Display report:
Screen Resolution: 1280 × 800
Panel ID: LG LD080WX2 wxga video mode dsi panel
xdpi / ydpi: 160 / 160 dpi
GPU Vendor: Qualcomm
GPU Renderer: Adreno (TM) 405
GPU ALUs: 48
Current GPU Clock: 400 MHz
GPU Clock Range: 220 - 550 MHz
GPU Utilization: 10 %
Scaling Governor: msm-adreno-tz
Refresh Rate: 60 Hz
Default Orientation: Landscape
OpenGL ES Version: 3.0
Screen is relatively sharp and bright. I wouldn't want to use it a lot for reading small text but it works fine for the target audience.
It is an IPS panel with a 800:1 contrast ratio and 330 cd/m2 brightness (advertised specs).
AIDA64 Battery report:
Power Source: Battery
Level: 62 %
Status: Discharging
Health: Good
Technology: Li-poly
Temperature: 25.0°C
Voltage: 3.772 V
Charge Rate: 485 mA
Capacity (Reported by Android): 4500 mAh
Battery life seems to be in the 8~10 hour range.
AIDA64 Android report:
Android Version: 5.1 (Lollipop)
API Level: 22
Rooted Device: No
Build ID: LMY47O release-keys
Codename: REL
Fingerprint: nabi/nabiX2/NBX208HQCG:5.1/LMY47O/3.1.0:user/release-keys
Incremental: 3.1.0
Java Runtime Version: Android Runtime 0.9
Java VM Version: ART 2.1.0
Java VM Heap Size: 128 MB
Kernel Architecture: aarch64
Kernel Version: 3.10.49-perf-gce13b3e
Marshmallow would have been nice, if only for supporting moving apps to SD cards.
AIDA64 Camera report:
<< Rear-Facing Camera >>
Resolution: 5.0 MP (2592 × 1944)
Video Resolution: 2.1 MP (1920 × 1080)
Focal Length: 3.16 mm
Focus Modes: auto, infinity, macro, continuous-video, continuous-picture
Video Snapshot: Supported
Video Stabilization: Not Supported
Zoom: Supported
Smooth Zoom: Not Supported
Auto Exposure Locking: Supported
Auto White Balance Locking: Supported
Flash: Supported
<< Front-Facing Camera >>
Resolution: 1.9 MP (1600 × 1200)
Video Resolution: 0.9 MP (1280 × 720)
Focal Length: 2.93 mm
Focus Modes: fixed, infinity
Zoom: Supported
Flash: Not Supported
In my humble opinion the cameras are pretty bad in anything but ideal light conditions - and then they barely approach mediocre. But my daughter loves being able to take pictures and never complains about the quality.
AIDA64 Thermal report:
tsens_tz_sensor0: 36.0°C
tsens_tz_sensor1: 35.0°C
tsens_tz_sensor2: 34.0°C
tsens_tz_sensor3: 35.0°C
tsens_tz_sensor5: 37.0°C
tsens_tz_sensor6: 37.0°C
tsens_tz_sensor7: 38.0°C
tsens_tz_sensor8: 38.0°C
tsens_tz_sensor9: 36.0°C
pm8916_tz: 29.9°C
bms: 25.0°C
battery: 25.0°C
Battery: 25.0°C
It runs cool.
AL3320 Light sensor:
BOSCH Acceleration Sensor:
BOSCH Gyroscope Sensor:
BOSCH Orientation Sensor:
BOSCH Gravity Sensor:
BOSCH Linear Acceleration Sensor:
BOSCH Rotation Vector Sensor:
BOSCH Game Rotation Vector Sensor:
BOSCH Gyroscope Uncalibrated Sensor:
BOSCH Step Counter Sensor:
BOSCH Step Detector Sensor:
It does NOT include a GPS or compass, which is disappointing as apps like Google Sky Map don't really work.
AIDA64 Apps report:
Almightree: com.crescentmoongames.almightree(v1.4)
Bag It!: com.hiddenvariable.bagit(v2.10)
BB Racing: com.vectorunit.purple.fuhu(v1.2.6)
Block Story: com.mindblocks.blocks(v10.4.12)
Bookstore: com.fuhu.wings.bookstore(v3.0)
CN Video: com.turner.cnvideoapp(v2.8)
Draw a Stickman: EPIC: com.hitcents.stickmanepic(v1.4.2)
Dream Pro Animator: com.vblast.dreampro.animator(v1.3)
Dream Pro Draw: org.pogi.DrawingPadFuhuPreload(v1.2.100)
Evertales: com.crescentmoongames.evertales(v1.1)
Fruit Ninja: com.halfbrick.fruitninja(v1.8.10)
Granny Smith: com.mediocre.grannysmith(v1.2.0)
iHeartRadio: com.clearchannel.iheartradio.controller(v4.11.0)
iStoryTime: com.zuuka.istorytime.fuhu(v1.1)
Lightbot: com.lightbot.lightbot(v1.6.0)
Maxthon Browser: com.mx.browser(v2.6.4)
Maxthon Kid-Safe Browser: com.mx.browser.kids(v1.2)
Monkey Boxing: com.crescentmoongames.monkeyboxing(v1.05)
nabi Clock: com.fuhu.nabiClock2(v104070101)
nabi Clock: com.fuhu.nabiClock(v104070201)
nabi Clock Minigames: com.fuhu.minigame(v104060301)
nabi Stopwatch: com.fuhu.nabiStopwatch(v104021201)
nabi Timer: com.fuhu.nabiTimer(v104073001)
nabi Weather: com.fuhu.nabiWeather(v104102702)
nabi Web: com.fuhu.nabiWeb(v104061101prod)
Panic Flight: com.Ama.PanicFlight(v1.3.3)
PaperMonstersHB: com.crescentmoongames.pmhumble(v1)
Puffin: com.cloudmosa.puffin(v4.8.0.2790)
Puzzle 2: com.ama.puzzle_f2p(v1.3)
Riptide GP2: com.vectorunit.red.nabi(v1.1.1)
School of Dragons: com.KnowledgeAdventure.SchoolOfDragons(v1.15.0)
Siegecraft Defender: com.blowfishstudios.siegecrafttd(v0.6)
Slingshot Racing: com.crescentmoongames.slingshotracing(v1.3)
Speakaboos: air.com.speakaboos.fuhu(v1.3.1.1)
Sprinkle Islands: com.mediocre.sprinkle2(v1.1.0)
Swim and Play: air.com.captainmcfinn.SwimAndPlay(v1.4)
The Counting Kingdom: com.littleworld.magicmath(v1.1.0)
Threes: vo.threes.exclaim.navi(v1.2.3.4)
Toca Builders: com.tocaboca.tocabuilders.freetime(v1.0.6)
Toca Cars: com.tocaboca.tocacars.freetime(v1.0.4)
Toca Lab: com.tocaboca.tocalab(v1.0.2)
Toca Mini: com.tocaboca.tocamini.freetime(v1.0.3)
Twisty Planets: com.firstsightgames.twistyplanets(v1.056)
YT Kids: com.google.android.apps.youtube.kids(v1.99.3)
This is a list of the apps that come with the tablet. I'll get a little deeper into the software tomorrow.
Hardware:
Manufacturer: FUHU
Model: NBX208HQCG
Brand: nabi
Board: msm8916
Device: NBX208HQCG
Hardware: qcom
Platform: msm8916
Product: nabiX2
Installed RAM: 1 GB
GPU ALUs: 48
Refresh Rate: 60 Hz
Level: 62 %
Status: Discharging
Health: Good
Technology: Li-poly
Temperature: 25.0°C
Voltage: 3.772 V
Charge Rate: 485 mA
API Level: 22
Rooted Device: No
Codename: REL
Incremental: 3.1.0
Zoom: Supported
Flash: Supported
Zoom: Supported
pm8916_tz: 29.9°C
bms: 25.0°C
battery: 25.0°C
Battery: 25.0°C
It runs cool.
AIDA64 Apps report:
