- Aug 6, 2003
- ---> NEW HOUSE 7/17/09 !! <---
- Thread Starter
- #21
it AINT easy, but the only way i have found is to put the HS on the IHS and HOLD IT FLAT while you press down the clips 1 @ a time in a X. but the trick is that the 2 clips "under" the fins are a "lil tricky" to get to try mounting it while the mobo is (still) out of the case.DaWiper said:(EDIT: @Joe Camel's last post)
I know. I have one myself. I currently see no way of mounting the xp90 without tipping it. That maneuver crushed ALOT of AXP cores. I dont have the guts(or the money) to try it right now. I probably will though.
update: no post.......... doing a "1 hour with the bat. out clear CMOS" and
ya, thats a 80mm Nado duct-taped to a copper socket A HS and modded to mount on my x850 xt (there are 2x screws under the duct-tape )
