Can I loop this back to the original question in light of the ECC RAM issue? I agree that S/W wise there is virtually no difference between Intel and AMD. Can I confirm that H/W wise AMD is a better selection at the low end when looking for ECC RAM support? My understanding is that one needs to get into enterprise class processors and motherboards in order to utilize ECC RAM with Intel and that there are lower level (e.g. consumer grade) AMD processors that do support ECC RAM.
I'd like to upgrade my NAS to something that supports ECC RAM and won't use a lot of power. At present it runs on an Intel J1900 (4 cores, 10W TDP) which performs admirably running Linux and serving via NFS. (It runs miserably trying to run a Gitlab server...) My question is how to find a selection of motherboard/CPU combos that support ECC RAM (and Linux, if OS support is required.) I'd like to rebuild with something that is reasonably power efficient (AMD?
) and matches present processing capability.
Thanks!
NB: And I'm , er, thrifty so a prebuilt system costing hundreds of dollars is probably not going to excite me. But go ahead and suggest for the benefit of the OP and others who might be interested.
IMO best bang for buck is a retired server that is full of (now cheep ) ecc ddr3 .
these are some examples of what I can find around my area .
Dell Precision 490 WorkStation $200
2 X Intel Xeon Dual Core 3.0Ghz
2 Physical Dual Core Processors Intel 5160
Altogether 4 Cores
16Gb RAM DDR2 PC5300F ECC
250Gb SATA 7.2K Hard Drive
DVD ROM Drive
Gigabit Network Port 10/100/1000
Tower Machine
Fully tested off-Leased unit with 3 Months Warranty
Upgrade to 32Gb RAM for $50
Or can you guys find something better ? For around the same $ +/- 100$ cnd
Another option from same site
Dell Precision T3500 WorkStation $200
HP Z400 WorkStation $200
Intel Xeon Quad Core 2.67Ghz
Intel W3520 Processor with 4 Cores and 8 Threads
16Gb RAM DDR3 ECC
DVD ROM Drive
Tower Machine
Fully tested off-Leased unit with 6 Months Warranty
Upgrade to 16Gb RAM for $50
Upgarde to 24Gb RAM for $100
Dell Precision T5500 WorkStation $400
Intel Xeon Quad Core 2.66Ghz
Single Intel X5550 Processor with 4 Cores and 8 Threads
48Gb RAM DDR3 PC10600R ECC
1Tb SATA 7.2K Hard Drive
DVD ROM Drive
Tower Machine
