- Aug 18, 2010
- Dallas/Fort-Worth
Am I looking at this right? Is the base server seriously running circles around FreeNAS?
I would use the word "destroying", but yes, the performance is quite less. Remember that the base server is my actual file server, which is running a full blown hardware RAID card and nine (slow) drives in RAID 6. It will gain speed from the RAID controller and lose a bit due to the hard drives I'm using (5k3000 5300 RPM) and RAID 6. The test server is running 8 drives in Z1 (~RAID 5) ZFS pool. When I get to the mdadm on CentOS comparison, we will see how it stacks up -- which is the configuration I'm more interested in.Am I looking at this right? Is the base server seriously running circles around FreeNAS?
I like this idea a lot. I'm thinking of dropping it down to 16 or 32 queue depth. That would halve the time required to run the tests. None of the tests really changed much after 16/32 in the queue.Oh and do the tests for 1-4 threads since it apparent they don't like multi-threading except reading, and it will cut down your test time. So you can spend more time swapping NAS OSes . You have a bunch to do after all.
I keep forgetting to mention this, but if someone have a spare computer or are using the software I'm reviewing, I would appreciate getting your opinions or experiences with it. No matter how vigorously I test, I can't test everything from every angle.
If you want to install it on a spare system, you wouldn't need to do the tests that I'm doing or have expensive hardware. Just your experiences with how it was to setup, configure, and use is valuable.
When I get to testing these, I'll try to send you a message. If you could, start making a list or write a paragraph or two (up to you) about it. I'll include a link in the review.I am currently running Naslite with 8 x 2TB and 8 X 1 TB drives and also a Openindiana box with IBM1015 HBA and Intel SAS expander in Norco 4220 case with 12 x 1.5 TB drive currently.
Any help gratefully given.
Doug
