I recently bought the Benq 822A dual format burner. I have flashed it to the latests firmware. The problem is the drive tells me brand new dvd +/- media does not have enough space to burn the selected file. I am using alcohol 120
I have tried installing the dvd-rw +/- drive on both master and slave IDE ports. The board is a Chaintech VNF3 250 that has 2x36ggb hd's in raid 0. The drive jumper is set to master as well
The drive can burn cdr media fine but I can not get it to burn brand new maxell or memorex media. The media I am using is 4x and I also notice that the media speeds shown in alcohol that I can burn at are completely incorrect, 63x??? Yet if I scroll the bar I can select 4x and there is a maximum burn feature based on media being used. Alcohol is a new program to me and I am not sure what it means when I open the prog and it shows the benq 8x4 dvd -rw drive and thena a virtual drive below it.
All feedback is welcomed cause I am stumped.
CK
CK
