Need a Decent cooler for My Newcastle.
They don't come with a fan, although most sites will let you purchase a fan with it that is paired for the HS.
yeah, get the freezer 64 and soem AS5 - from what i've seen it performs better than the xp-90 with the stock base (you usually need to lap the xp-90's base to make it flat/free of nickel plating)
otherwise, get the XP-90 and a 92mm fan that pushes atleast 50CFM
I don't need the best cooler because Overclocking is not a concern.I definitely don't need a freezer or the XP120.
The XP90 looks like it's a decent size(Not gigantic).I just want something better than what I have.
Freezer cheaper than XP90
THe freezer is cheaper and SILENT.Major plus would be the silent.I love silent.With a side of silent.Servered up with a heeping pile of hot SILENT. :beer:
MassRaptor
Personally I'd choose Freezer over XP-90, perhaps even forgetting price issue. Always, if you decide for high OC, you could replace fan with some 92mm as Yuriman did. ANd with 460g of total weight it's not that monstrous...
hehe, that's just great tower-style cooler, no firdge magic :)
massraptor was simply joking about name used and its performance.
