Need a good NF2 MB for OCing
bulk88
NYC
I had a rev 1 (166 only) NF2 Epox 8RDA MB. Unfortualy it's ATX conector melted for uknown reason. The CPU, RAM, and everything else is fine. Its my rig in my sig. I need a cheap good replacement MB based on the NF2, it can have embedded video (better than my GF2 GTS), and I really want the MCP-T southbridge. It needs to have really good overclocking and monitoring features. SATA is not needed and would be annoying in my case (no money for SATA drives in the next 2-3 years) and I don't need the extra cost.
Hrm well the Abit NF7 and NF7-S are the 2 best ocing mobos for amd. If you don't need the extra features on the NF7-S the NF7 is pretty cheap for ocing you get out of it.
The NF7-S used to be the best. But from what i've been reading
the recent ones don't do as well.
Has any NF7-S ever reached 262fsb without hard mods?
If not you might want to take a look at Soltek.
Yeah, that's right. Soltek. :p
SL-75FRN2 = 262fsb
I run the shuttle AN35N ultra, check sig for details on my rig. Balrog runs that and I know he'd praise that board too.
SL-75FRN2 = 262fsb
i had a nf7 that can do 280mhz without any voltmod, totally unstable but have done it, cpu int disable, dual channel 3-4-4-5 timings (270mhz cpu int enable)
and now i have changed it because had multiplier problem, and have a nf7 that can do at 1.5v vdd, all stock no vmod 265mhz for shot (with sandramem) DC cpu int enable 2.5-3-4-11 and 4gb/s sandramem, and no issue with any multiplier!
but it's not a single board that makes the difference...
for now my votes go to NF7 (or NF7-S) V2.0 and DFI Infinity
DFI seems to have better bios, better fsb clocking but only 2v vcore overvolting (simple to vmod)
Good board, especialy for the price but he specifically asked for the MCP-T southbridge which it lacks.
If you have to have the MCP-T then the Abit NF-7 flavors are a good choice.
"totally unstable" ... Gee, that's useful. :rolleyes:
Sorry if that seemed a little harsh. I just get so tired
of people quoting their highest post screen instead of
what their system will do while STABLE. :p
you say that soltek is a good board and probably the highter clocker board...
i say that with my abit i can hit 280 totally unstable, and in the 3d that you have linked with soltek hook say this
XP2000 AQXEA 256k Cache (Thorton) with L2 mod to activate the 512K extra Cache: The board in the first intent reached 262FSB. At moment I don't test the FSB stability.., bun I think that it will higher than 245 Mhz.
so your answer to my post is totally senseless, because i have answer to your first post on soltek...
also Hook can hit 265 and can't benchmark anything at 265, have ram a 3-5-5-8 and probably very poor performance... (and cpu interface disable)
and probably can't use multiplier highter than 8x, because nforce2 gain 15-20mhz of fsb with multiplier 7-7.5-8x... so if you can hit 270mhz at 8x you probably can hit only 250mhz at 10x, and with the same instability that at 270mhz 8x....
so watch my NF7-S V2.0, without ANY vmod, with 2*A-Data PC4000, cpu interface enable (with disable gain another 10mhz of fsb but is useless), timings at 2.5-3-4-11
so i say, Soltek (without extreme vmod) isn't absolutelly the best board for overclocking, probably a good board, but the best are Abit NF7-S V2.0 and DFI Infinity/Lanparty Rev B
