Need a new case...requirements inside
EarthDog
Gulper Nozzle Co-Owner
Cbus!
Looking for a new case... the smaller the better. Like, MicroATX (likely using Mini-ITX board).
Reqs.....
* Must fit 3.5-slot+ (150mm) and 360mm long GPU
* Must support ATX PSU
* Must have FRONT USB 3.2 Gen 2x2 (20 Gpbs) Type-C port
* Must support 3x120mm AIO
What's out there?
Thanks in advance for the help!
ITX/mATX that supports 360mm rad and 360mm graphics card is pretty much ATX :)
Maybe APNX V1. I guess the VGPU version is still unavailable, but the regular one supports long graphics cards and has a GPU holder. Maybe you will find something better.
If you wish to write a review/preview, I can get you a sample :)
I suppose I can go down to 2x120/140mm, but that means I'd have to buy an AIO. 9900X should be fine underneath it.
I'm trying to use existing parts as the monitor is going to kill me in this upgrade.
I wish more chassis specs would list WIDTH for GPUs too...
I have Jonsplus i100 Pro. It's +/- the same, but for ITX and one slot less on the bottom (still large holes and space for slim fans). No matter how the graphics card was installed, the airflow was a problem for a 250W card.
I doubt any small case will have good enough airflow and enough space for a large 300W graphics card.
It will house a 5090 so, it would need airflow..........
Looks like ITX isn't a thing for that... damn.
APNX case is winning.......but not much smaller than my Y60....
I got this one for my wife. Supports full triple width GPU and a full sized PSU.
Does not support larger than 240 rad and does not have USB-C.
The one in your link is also SFX/SFX-L PSU not ATX and will only house a 240/280mm AIO. It certainly does look interesting though.
Yeah, it looks like additional sacrifices, read $$$, may have to come into play. Nothing like a 1KW SFX PSU, lol. There's a difference between physically won't fit and, 'damn I need to pay more money'! :p :rofl:
