Need a New Northbridge HS/Fan. Suggestion's?
craigiz1
Pompano Beach, FL
It seems my fan is going to die any time now. I am getting ready to mod the interior nicely so I thought I might get a nice good looking northbridge cooler to go with the new looks.
Any suggestion's.
Good cooling is a must. Not just looks.
I am using a SLK-800, so clearence may be an issue.
(Board in sig.)
Thank's.
Optimus Prime
ya mane i have 2 suggestions for you... well actually 3 depending on the situation.
I think the 2 nicest nb coolers out there are the swiftech found here
http://www.sidewindercomputers.com/swmc3.html
and the microcool model found here
http://www.sidewindercomputers.com/minochcokit.html
both of these are super pimp however if clearence is a problem they might not work. if u have a problem clearing ur cpu sink then u might want to think about the ThermalTake Chrome orb. Its cheap and has a 12.5 cfm fan which is pretty heafty for such a small unit. u can pick one of those up at the standard www.newegg.com
Prime
