welp i did some homework and it looks like the way to go for me is.. Radeon x800 series... and just pray to GOD you have one that can unlock its pipes prety easy.
welp.. which cards do you guys recommend me getting for a good chance to OC.
My system is 2800 Barton @ 2.5Ghz
and i'll be attaching my Zalman heatpipe on this with a 80mm tornado blowing on it.
Broke my 9800 pro from taking my VGA silencer off and installing a Zalman heatpipe.
So far iam thinking about buying 1 of these 2:
http://www.newegg.com/Product/Product.asp?Item=N82E16814102065
or
http://www.newegg.com/Product/Product.asp?Item=N82E16814102606
which one would be better for OCing?
i'll also accept any recommendations.. i am really looking forward to getting this thing back up and running, i accidently broke the 9800 pro from taking off a VGA silencer and putting on the Zalman heatpipe.
or
