- Aug 1, 2003
- Round Rock, TX
System Components:
(Newegg.com)
This case features one 120mm exhaust port on the back and one 120mm intake port on the front.
I am planning on using the back port for one of the radiators and I plan on drilling another port on the top of the case for the other.
My Plan:
Two independent loops, one for CPU and Chipset and one for both GPU's.
The pumps will be hung upside-down from the roof of the case (Is this okay for the pumps?). There will be a T-line up at the top between the pumps and radiators leading to a Fillport in the top of the case. Fans will be attached to the radiators using 1" shrouds and will be pulling air through the radiators and exhausting it outside. I will eventually add fans to the inner-side of the radiators once I can find another source for Globe fans. I will be using 1/2" ID tubing throughout.
Watercooling Components:
I plan on running two independent loops in the following configuration:
This will be my first attempt at watercooling. Please let me know if there are any changes I need to make as I want to make sure I do it right the first time. Also let me know if I've forgotten anything.
Thanks for the help!
-Josh
Code:
Lian-Li PC7077B full-tower case
OCZ Powerstream 520watt power supply
Asus A8N-SLI Socket-939 motherboard
AMD Athlon FX-55 CPU
1GB OCZ PC3200 Platinum Rev2 memory
2 BFG Nvidia 6800 GT PCI-E graphics cards
SoundBlaster Audigy 2 sound card
Western Digital 74GB Raptor hard drive
Plextor Premium CD-RW drive
(Newegg.com)
My Plan:
Code:
Danger Den TDX CPU block - brass top - #4 nozzle $ 61.94
Danger Den Maze4 GPU block - brass top (2) $ 102.90
Danger Den Maze4 Chipset block - brass top $ 38.50
AquaXtreme 50Z-DC12-T pump (2) $ 178.30
Black Ice Pro radiator and shroud (2) $ 99.00
Danger Den fillport for T-line (2) $ 23.90
Polypropylene T-connector (2) $ 2.00
HydrX coolant (2) $ 6.58
30 black plastic tubing clamps $ 15.00
10 feet of Tygon R3603 1/2" ID - 11/16" OD tubing $ 20.50
Total before shipping $ 548.62
Code:
Loop 1
| Res Pump Rad CPU Chps |
Loop 2
| Res Pump Rad GPU1 GPU2 |
-Josh
