Hi, i am looking into building a dual Athlon 1.5Ghz PC with the new tyan board, i am going to mount it into a 1U rack mount server case, for business purposes. This is the rack case im looking at http://www.gorilla.net/gorispro/rak-103x_rackmount_case.htm
My problem being, the Athlons will not be overclocked, and i do not mind high temps as long as it is 100% stable, I need a heat sink and fan that will fit on the cpu but inside the case
1U is 44mm high, by the time the motherboard and athlon is on, i probably have about 30-35mm to play with for a heat sink and fan, any ideas??!?! I dont think ive seen a small enough one, btw, Length and width is not a problem, just height.
ALso the the biggest ive seen the PSU in these cases is 250 watt, this wont be enough to run a dual 1.5 Ghz pc with SCSI HDD and 1 GB of DDR ram will it? IF not, has any one seen a PSU that fits into a 5.25" drive slot??
