Heya all,
Would like some help on my issue. I currently have a rig where the MOBO died on me so I figured why not upgrade for a little bit more than getting a replacement MOBO for my system. So here is what I have now...
DFI LANPARTY nF4 SLI-DR socket 939 (DEAD)
AMD Athlon 64 3700+ San Diego 2.2GHz OC'd to 2.74 (IIR)
2 OCZ Platinum 1GB DDR 400 (PC 3200)
I am looking to move back to the Intel line of things and to be honest, I want to stear clear of DFI as well.
So here is my question...I am a MMORPG player...Play WoW now, and looking forward to WArhammer I want to stay at the very least, as fast as I am now, but to be honest, I am so far remove from Intel and current architecture trends that I am almost clueless as to what to get that will be pretty decent. So for as cheap as I can get, I want to make sure I can play wow at the same level (At max settings) and I will be set up with only a minor upgrade for WAR.
I came across this thread http://www.ocforums.com/showthread.php?t=483065
I was thinking the entry level system to replace what I have, but I am not sure how it compares to what I have/had. Or would the middle of the road put me there...or hell...can ssomeone recommend something better??
Thanks a ton!
(System is down so looking to buy soon (I am getting the shakes with no games)
Thanks a ton!
