- Oct 15, 2012
Hello, i'm looking to get some parts together to build my first gaming rig.
I currently have a Packard Bell Easynote LJ65 laptop, which really doesn't cut it for me gaming-wise (have to run everything on low to get near-decent fps)
I've already done some googling for parts, and have my eye on a few of them, but i have no idea what other parts i should get, or even if the parts i want are compatible with each other.
CPU:Intel Core i7-3930k Intel Core i7-3770K
GPU:GeForce GTX 580 GeForce GTX660 Ti
RAM: 2x 8Gb Kingston HyperX Red DDR3 1600Mhz
Audio Card: Asus Xonar Essence STX (Yes, i do want one unless MB sound=better) Never mind, i have USB speakers.
Case: Lian Li PC-9F Black Aluminium
Motherboard:Gigabyte GA-Z77X-D3H ASRock Z77 Extreme4
BluRay/DVD R-W: LG WH14NS40
HDD: 1.5TB Barracuda ST2000DM001
PSU: No clue
OS: Win 7 Ultimate (Have it already)
SD/Media Card Reader: Don't know, really only need it for SD on my camera.
Fans/cooling: Don't know, but a little better than necessary would be good, so that there's breathing room for future overclocking/upgrades.
My budget is around €1000, but of course less is always better.
I already have most of the peripherals, just need a nice monitor, preferably with USB (2.0/3.0) ports on it to connect my speakers.
I'm also not quite sure where to order all these parts from, i live in the Netherlands but perhaps some local stores might have them.
I don't plan on overclocking, but if i do want to later on down the road, having the option to do so would be nice.
I also don't really care about the loudness of the thing, since i'll probably be wearing my headset anyway.
I would like to be able to upgrade parts of it in the future, but i do hope i don't have to for a while after the build is complete.
In any case, these are my questions;
Are the parts listed above compatible with each other, and if not, what alternatives are recommended?
Do you have any tips for a first time computer builder?
What monitor should i get? I'd prefer a 16:9 aspect ratio one, and not too expensive if at all possible. 3D would be nice, but definitely not required.
Thanks in advance,
-XDMickeYXD
CPU:
GPU:
Motherboard:
PSU: No clue
Thanks in advance,
-XDMickeYXD
