I'm looking at getting an Intel Arc A310 or A380 video card to use with Handbrake because I use Handbrake a lot and I seen a few video's on youtube by guys that seemed credible that using an Intel card will boost your speeds when using Handbrake and other video processing software which is what I want,I won't be using the card for gaming so I'm not concerned about that just getting more processing power.
Have you guys had much to do with the Intel cards and if so how did it work running Handbrake,these are the 2 cards I'm looking at.
https://www.amazon.ca/ASRock-A310-P...id=1716283452&sprefix=intel+arc,aps,89&sr=8-2
https://www.amazon.ca/Asrock-Challe...id=1716283452&sprefix=intel+arc,aps,89&sr=8-1
Another question I have is that I use a GTX960 and GTX570 card in my 2 rig's because I don't really game and I needed a card because my one cpu didn't have built in graphic's.
What the problem I run into is that when I try and use the HDMI mini port no matter what setting I select in Windows 10 or 11 will fit my monitor correctly unless I use the DVI port.
The monitor that I have is a Viewsonic VX2439VM and it's an oldie but a goodie and has always worked great,will I run into the same problem with an Intel Arc card because they have HDMI port's only.
https://www.viewsonic.com/uk/products/sheet/VX2439wm
This may sound really stupid but I was just looking at my monitor and I think I need to set the video input to HDMI,I will have to give that a try.
I have always ran DVI and never thought of changing that setting.
Post magically merged:
