Need advice: Voltmod Maxsun HD 6570
ytszazu
Hello there,
(First of all, my apologies as i posted in the wrong forum, how to move this post to GPU forums?)
Need advice to further increase the overclocking capability of Maxsun HD 6570.
System:
HP 6305 A10-5800B
16 GB RAM
Maxsun HD 6570
Dual Graphics (Can detach if needed)
Story:
1) New cards are priced too insanely in my place.
2) Ordered a HD 5750 online, 1GB DDR5
3) Got cheated and received a HD 6570, 1 GB DDR3 instead.
4) So, in a show of unhappiness, I am going to overclock the HD 6570 until it achive HD 5750 performance (kidding?).
What have been done so far:
HD 6570
1) GPU base 650 Mhz, RAM base 667 Mhz Base 1.05V
2) Very bad default overclocking ability in MSI afterburner, so I RBE it.
3) RBE - GPU stable to 725 Mhz, RAM stable to 900 Mhz, If i adjust any of the voltage info above 1.05V, it defaults to 0.9V, Max temp was 46 C. No wattage adjustment can be seen.
4) Overclock GPU/RAM any higher than above will result in crashing.
5) Seeing it has a temperature and voltage headroom, what are the next steps to increase voltage, can it be done by software, or I need pencil or solder mods? (I have gpu board pictures - if needed)
6) Does terascale GPU's have a wattage max limiter like GCN 1.0 GPU's?
Thank you,
Regards,
ytszazu
I am sorry, i just realized this is the CPU thread, how to delete or move this post?
