Hey there people I have some questions, I am relatively new to building pc's this is my first attempt:
Asus P4S533 with P4 2.4
Zalman 7000 cpu fan (92mm)
Geforce 4 v8170 64Mb
768 Mb ram 2700 (3 x 256)
Raidmax 330W PSU
The part I didnt do was the fans which I have two case fans on the side that both appear to be blowing out(one seems to be blowing warmer air than the other). Now when I had the 2.4 running with stock intel fan system was idling around 33C and also with stock fan when I OC'ed it to 2.52 at 1.55 V it stayed around same temp (33C). The first of my problems is that when i put the zalman fan on the cpu wasn't any cooler. Could this be due to not putting the HSinthe precise spot over the cpu??????
Right now I am running at 160 FSB which puts cpu speed up to 2.88Ghz with 1.55V. This is the highest setting I have achieved that passed the torture test of prime95, however when running counter-strike the cpu temp rises to almost 55C, is this dangerous???? and what is the danger zone I should be staying away from?? Also is prime 95 a sufficient test, as my system seemed rather stable at 2.93Ghz 263FSB but wouldnt last 1 minute on the prime95 torture test. Should I be going that high??? does anybody know the limit of this motherboard cpu combo?? is 3Ghz pushing it?? Do I need more case fans??? both fans i have now are very small? should i get more and is it important how and where they are placed? and what direction they are blowing? I would appreciate anyones input
Raidmax 330W PSU
