Need C++ help
Zerix01
I'm having some problems with passing a string to a class and dynamicly creating more of the class type. Since I'm still learning I created a new program that only does this one thing so I can test it out and see what works and what doesn't. I keep getting segment faults when I try to allocate new memory.
Code:
#include <iostream>
#include <string>
#include "stringh.h"
using namespace std;
int main()
int i = 0, a = 1;
string word;
St *str;
str = new St[a];
word = "Word";
for(i = 0; i != 3; i++){
a++;
cout << a <<endl;
str[i].setVar(word);
cout << str[i].getVar();
cout << endl;
return 0;
And here is the header
Code:
class St
std::string w;
public:
	void setVar( std::string a)
		w = a;
	std::string getVar()
		return w;
The output looks like this
Code:
2
Word
3
Segmentation fault
2 <- so it increments without a problem
Word <- and the string was set into my class correctly
3 <- increments again
Segmentation fault <- I assume this means that although "a" was incremented to 2 and 3 it never dynamicly allocated the new memory and when I try to store my string in the new space it seg faults. What am I doing wrong?
Trombe
Austin, Texas
str[3] is beyond the bounds of str, as it was initialized with str = new St[a]; when a = 1.
you are getting confused with your i and a variables
Zerix01
Zerix01
Ah crap, I see what is going on. So I need to determine what 'a' should be before initializing str. I had thought I was able to do this before just only when using numbers instead of strings, so I thought it was a string issue.
Thanks.
FireMogle
Lawrence, KS
Code:
int main()
int i = 0, a = 1;
int b = a;
string word;
St *str;
str = new St[a];
word = "Word";
for(i = 0; i < a; i++){
b++;
cout << b << endl;
cout << endl;
return 0;
This should make it so that no matter the value of a you initialize the size of your array to be, your loop will always be valid.
