Need feedback on choice of mobo for my PIII700??
hereandgone
Hello,
I think my BE6-II mobo series 1.0 may be hooped. I plan to try a few more things first. Recently changed cases and went from 230 w power supply to a 250 w. For some reason since installing my keyboard connection does not work and I can not enter the sub menus within the bios. Do not know if I have a short or what. Have removed the battery and reset the cmos and still no luck, final try will be removing mobo off the metal side plate and only leaving the vid card in to see if it will boot up and let me get into the bios to make settings changes, if this does not work I am stumped. Will Abit warranty the board without proof of purchase, I have been told they will.
It is very strange that the system worked fine before changing cases, and I did use the plastic washers on the bottom and top of the mobo before screwing it down to the metal backing.
I plan to buy a new mobo , I love the Abit BE6-II for the ease of soft menu and the stability. Can anyone suggest some other choices of FCPGA boards as I now use an Iwill slotket. I have given thought to Asus CUVX4-C cause of the price. I need an ISA slot so the CUSL-2 won't work
I overclock so want a good stable board that is easy to make changes in the bios. My gear is a retail PIII700, Iwill Slotket, Asus Geforce DDR Deluxe, REaltek Nic Card, Soundblaster PCI128, USR 56K ISA modem and Maxtor 27 gig ATA66 drive 7200rpm, Yamaha 8x8x24 burner , Pine CD rom drive, 2 x 128 megs PC 133 ram ( Nec and Infineon)drive.
Thanx
hereandgone
First, there's no need to use any kind of insulator on the mounting holes of a mobo. The traces there are at ground potential and are meant to be placed directly on a standoff without any spacer or insulator.
When putting a mobo in a new case the usual mistake is having a misplaced standoff that doesn't line up with one of the holes on the motherboard. This can cause a short where it touches the mobo. If you're lucky, there will be no damage and when the standoff is removed, everything will be OK. If you're not lucky, the circuitry touched by the grounded standoff will be fried and the mobo is toast. Another problem occurs when the mobo touches the side of the case somewhere.
So, take out the mobo and check for these problems before getting a new one.
Another VIA 133A (yuk) FC-PGA board to consider is the $88 Soyo SY-7VCA2. It's got lots of FSBs, an ISA slot, and ATA100.
