need good mobo (100$-225$ range)
gspot102
i have a qdi mobo and I feel it is no good can some1 suggest a decent mobo that oc's nicely? and supports a p 3 800 and pc 133 ram--thanks i know there is someone out there to answer my prayers
Alot of people, like myself, are moving away from the BX chipset and moving on to the i815E chipset. The Asus CUSL2 motherboard has been gaining fame as a superior overclocker with almost the same performance as the BX. The CUSL2 supports AGP 4x as well as processors with a front side bus of 133MHz. If you already have a video card as well as a sound card, then get the CUSL2-C. Buying the CUSL2-C will save you about $30-40.
It seems the BX133 RAID is pretty well liked on a couple of forums I read. I just acquired the VP6 dual cpu board, and it wouldn't be bad with a single processor- it has all the goodies- ATA100 and RAID, plus the option to drop a 2nd cpu in later.
Don't buy an Asus P3V4X--like I did--unless you get an ICS clock chip.
The new mobo rev is pretty much a "nuetered" with its Winbond "16-less-fsb-settings" clock... :)
Kris
