Need good NB cooler
jbox33
Pennsylvania
I'm looking for a good NB HSF and need some ideas. It can't be any larger than a stock cooler however because I have the MCX462 HS on my CPU and the north bridge is too close on the Shuttle AK35GTR to put anything larger there.
Any ideas would be appreciated.
gone_fishin
BandSaw King
U.P. Michigan
Just about any square heatsink for older processors (because thy're smaller to start with) can be cut to the size you need with a hacksaw and epoxied on.
Shroomer
member with no avatar
Ohio
Zalman (sp?) makes a nice one that's pretty big, but doesn't come with a fan on it. If you are creative, I'm sure you can come up with something.
jbox33
jbox33
Pennsylvania
I would rather have one that I could use the mounting holes with. I was planning on using ASII and bolting it on with nylon bolts so I could get good contact.
Any ideas in this direction?
jbox33
jbox33
Pennsylvania
Yea I saw that one Shroomer. I was just hoping that there was something better out there that I could use other than a NB WB.
I'm not into the water cooling thing yet. Oh well. Thanks anyway. I'll have to find a HS I can modify for mounting.
NASsoccer
On a string I was held Senior
i live
will a crystal orb fit your NB. Many have used it for that and i plan on doing the same thing.
jbox33
jbox33
Pennsylvania
Didn't want to repeat it so I just quoted myself.
In fact I had to modify the current NB HS just so I could mount the MCX462 heatsink.
Shroomer
Ohio
The link that I posted has nothing to do with watercooling. It's a heatsink designed to go on a NB.
(edit)
After reading that again, I now understand. Why is that one so bad? It's the same size as the northbridge, but is MUCH higher than a normal NB HSF. Just slap a 40mm fan on and you're good to go!
Ugmore Baggage
Zalman now makes an all-copper chipset cooler that looks very effective. I don't know where to get it, but I haven't looked either... :p
jbox33
jbox33
Pennsylvania
Ok I found it here .
It's not available yet but will be soon according to their site. Looks promising. Throw a fan on it and I think it will work good. Thanks for the info Ugmore:D
Hmmm... I checked it out again and it looks like it's aluminum. May not be the one you were thinking of but I can't find any others.
