Hi, guys I wanted to ask your opinion about my PC overclock Settings, this is my first time trying to OC my PC, by reading OC guide form all you guys and you tube. I think i already got my CPU settings, but i'm not really sure if i'm making a mistake. Anyway this is my current pc specs:
CPU: Intel 4790K
Cooler: Phanteks PH-TC14PE
Memory: Corsair Vengeance 2 x 8Gb [cml16gx3m2a1600c10]
Motherboard: Asus Z97 Pro
GPU: Intel Stock HD4600 [ Saving money to buy a good GPU card]
Power: Xigmatek Vector S750 Watt
Case: Fractal Design Arc Midi R2
My final CPU is 4.7Ghz at 2.54 volt at manual mode,(Screenshot no.1,2,3,4) are my BIOS settings. and (Screenshot no.5) is screen shot of Asus Ai suite 3 "TPU".
i test it with AIDA64 for an hour and the max temp is 76 Deg. (No Screenshot - Forget to take photo)
Then i Tried to make adjustment from manual voltage to adaptive mode, using Asus Ai suite 3 "TPU", because i don't know how to change this setting from BIOS. and also Overclock The GPU from 1250mhz to 1500mhz using adaptive mode as well (Screenshot no.6)
Then i test it again using Aida64 for an hour. and the result (Screenshot no.7)
I'm happy with this result but, what i change form Ai Suite 3 doesn't save on bios.
What bios setting do i need to change to get (Screenshot no.6) settings
Sorry if my english terrible,
Thank you All in Advance
CPU: Intel 4790K
