Talk about carried away?
heh - look below at my sig - i just built this box a couple weeks ago
the pD 840 dual core was 60c idle with factory intel HSF
i was going to send it back
but everyone here said it was fine - that the dual cores produce twice the heat
so after running it about 8 hours, i went and got the thermaltake bigwater kit at compusa
i did not do no research at all - i was in a hurry to get temps down
now i added sli blocks and an extra radiator and i'm still not satisfied
so i'm about to order...
D5 Pump
Black Ice XtremeIII
the DG Sli low profile gpu blocks with mem heatsinks
the DG northbridge chipset block
i have not made up my mind on cpu block
i'm the one getting carried away
<-shoot me - my ole lady already has the gun loaded - haha
The cheap thermaltake drop temps from 60c to 40c
but i want a nice looking 1/2" tubing system thats top dog on the block
I won't be happy till i get it...
The botton line here dude...
For 149.99 you can't beat the thermaltake big water kit
it does its job pefectly
you may get an extra 5 or 8 degree drop from the best custom built system
cuz as i figure it, you can't get temp as low as room temps anyway with just water
my pump has only 1/4" inlet/outlet
it won't even pump 25g/h - its rated at 90L/h
I WAS TOLD by a couple people in here that adding extra radiator and sli blocks that this pump would * NOT * work
WRONG - works great for what it is capable of i guess
the pump and resorvior can only use 1/4" tubes
but i dropped 1/2" tubes from cpu block into sli cards and out to both radiators
webcam shot - you gotta look close - its not a good cam
http://www.carolina-customs.com/snap-13.jpg
and my current temps here...
http://www.carolina-customs.com/snap-16.jpg
Good luck with getting water on your system
It is the way to go to drop temps
I don't think me being the top dog on the block will drop my temps another 20c from this thermaltake system
I'm a noob to all of this so thats my experience so far
Top Dog $$$
20c plus drop $
its up to your pocket
good luck
~RD
