I have a 3.0E and it is running at about 125 and up to 140. I need it to be cooled alot but i don't want use liquid cooling. Any recomendations on what i should use as a heatsink and fan?
that's about 49°C idle and 60°C load, so not bad for stock cooling on a Prescott. Having the XP-120 or just a good thermalright with a powerful fan will lower your temps a lot. You can wait for the XP and put a good 120mm fan on it, or you could get the SP-94 and put a Delta HHE on it, both perform really well.
Both arch and I own the HHE ( he's given his of approval LINK ), and I highly recommend it for cooling the thermalrights... look at the temps in my sig .
