Need help finding 2 '86 chevette heater cores.
sevilla_jjl
I'm in the San Francisco bay area, and I've been looking for 2x '86 chevette heater cores. GO/Dan is backordered on the part number that so many of you guys are using. GM has discontinued the part. Autozone cancelled my order, then raised the price by $10.
Any help is appreciated.
Thanks
-JJ
Korndog
California
did u try a car junk yard? i went to one in concord/walnut creek and told them i was a starving student so they gave me a discount on stuff, i wasn't looking for heatercore, but did come by a few..
S
sevilla_jjl
it seems almost less trouble to buy one new for expensive, then to repair a pick and pull
Korndog
California
usually don't need repair, if you're looking for a mech. part on the other hand, hose need repairing, and sometimes are flat out dead.
i got stuff for 25cent a pound
heatercore is what? 2-3 pounds?
anywho, dtek is a good suggestion
39 bucks painted, or 31 not painted
www.aquastealth.com actually sells a painted one for cheaper..
35 bucks, and the shroud at aquastealth is cheaper as well, 11 bucks
and then there's always ebay..
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33548&item=2451261041
S
sevilla_jjl
Thanks for the ebay link, i'll check them out. Problem is, i bought 2 strouds for a 6x6 hc
E-Licious
Klownin79 said:
You can either go to a junk yard and hope to get lucky or go to D-tek where you will get lucky.
I'm sorry, but that sounds kinda dirty. Kinda like the difference between dating, and calling an escort service, if you know what I mean. ;)
Napoleon
Richmond, VA
ya they're 27 at autozone now, when i get a lil xtra cash im gonna go to an auto parts store like pep boys or something, and ask for 2 of the cheapest heatercores, the chevettes arent the only ones out there, they work the same
