My (some soon to arrive, I hope) hardware will consist of:
Q9450 ES
Rampage Formula
4 Gb PC8500
2 x 3870X2 1 Gb
RaptorX 150Gb
2 x T166 500Gb
Now for this hardware I currently only have an Enermax Liberty 500W PSU, which as far as I can tell is far from enough...
Since I have a Lian Li PC-A10B case which supports dual PSU's I'd really like to take advantage of this feature...
Now as I figured it out the new PSU which I need is only gonna be running my dual 3870X2 cards, and for that I am gonna need 2 x 8 pins switches, so the PSU needs to have that... (My Enermax has none, it only has the regular 6 pins, and if I'm not a complete idiot I would like to think that 500W for CPU, mobo and harddrives is more than enough)
So I was wondering if you guys would be so kind as to recommend me a good CPU, price isnt really any of my concern, but I was thinking in the range of 600-800W since I don't want it to be overkill...
I am not gonna name any of the models I've been looking at, because I want YOUR advice of what I should get, and not be influences by some of the PSU's I've looked at...
I would appeciate it very much.
Thank you in advance
Cown
Q9450 ES
Rampage Formula
4 Gb PC8500
2 x 3870X2 1 Gb
RaptorX 150Gb
2 x T166 500Gb
Cown
