- Jun 16, 2012
- new jersey
hey guys its been a while since ive been on here, on a new account because i dont have the email my old one was under...anyway
Just bought a brand new viewsonic freesync monitor so i got a displayport cable off amazon plugged it in and BOOM i loose a SSD. I dont think it was just coincidence. i turn my rig on. the screen flashed and then some shortcuts whos paths where to my F: drive where now white icons on my task bar. Doesnt show up anymore in the bios. tried everything to get it running
so i look into it some more online and it turns out that display ports have 20 pins and the 20th pin provides power. power that can feedback into your desktop even when its not on. In my case it turns on my lights on my r9 390 graphics card. The safe way to go seems to be to buy a 19 pin cable. which i cannot find anywhere. its like they dont make them anymore. so im wondering if anyone know where i can get one or if anyone knows of a safe 20 pin option. like a higher quality cable that doesn't provide power back to my pc. something with some kind of fail safe.
