- Oct 14, 2002
okie, basically, here is my computer's setup:
300W P/S
AMD T-Bird 900MHz (stock hsf)
Asus A7V mobo
256MB PC-133 SDRAM
Winfast GeForce2 GTS 64MB vid
Sound Blaster Live! Value
Kenwood 72X cd-rom
Ricoh 12x10x32 cd-rw
1.44 floppy
Maxtor 30gb ata100 hdd
my temps:
cpu idle: 59
cpu full: 61+
case: 36-39
video card edge: 54
video card surface: 64
lots of times, for no reason, my com just stops working (i could be surfing, doing hw, whatever. all of a sudden, it would just not work. but sometimes, the mouse can still move) or, i get a lot of errors. (it can be those illegal operation ones or blue screen ones) i've had this com for 2 years. i keep getting several errors. there are other smaller things too, but they aren't as big a problem. i've been trying to fix the problem but can't fix it. i don't want to take it to a store because they usually cost money to take a look at it and usually after i pay them... 50-100. they say there was no problem, or they don't know what it is. can anybody help out? so far, i've come to a few conclusions (not sure if they are correct tho):
a) the ram may be bad
b) it's a heat problem
c) both of the above
if it is ram, sd-ram is quite expensive. 256mb cas2 pc-133 sdram from crucial cost $150. 256mb pc-133 from kingmax is $100. for solving heat problem, i was thinking of a sk-6 and a 31cfm thermaltake fan, as well as 2 panaflo 21cfm case fans, and crystal orb for vid card. those would cost over $65. i'm skeptical of spending over $200 because i'm still a high school student and this com already cost me $3000 when i bought it. so think it might be necessary to get all those upgrades? hm. it's pretty long msg but thnx for ne help tho
300W P/S
Asus A7V mobo
256MB PC-133 SDRAM
Kenwood 72X cd-rom
1.44 floppy
my temps:
cpu idle: 59
cpu full: 61+
case: 36-39
video card edge: 54
