need help finding tapiaddr.dll file
axhed
cleveland
found a couple online vendors but i don't feel like shelling out $20 for this one download. it's on win95 disk 11 or the cab11 file.
i had my two boxes going through a router and both were working fine this morning, then i tried to fix it. i installed a usb ethernet port to free up a pci slot for the mx420 card and that corrupted the tapiaddr.dll driver or something and now that comp can't even ping the router.
axhed
axhed
cleveland
thank you for your help...
however, it appears there's more to the problem than just that file.
El<(')>Maxi
Blank Senior Member
Seattle
Check your device manager to see what the status of the devices in question are. Then make sure there are no IRQ conflicts.
