Lo guys.
Just got a new system and I want to put it to the max I can with OCing.
My current system is:
i3 550
P7P55D-E
CoolIt Eco ALC 120m CPU cooler
8GB DDR3 1600 w/ Heatsink (I'm using borrow memory from a friend atm until I decide what memory to get. ATM it's Kingston HyperX. Soon it will be G.Skill RipJaw)
GTX 460
I tried pushing the system to 4.5 but got BSODs under load.
The biggest issue I have with OCing is the voltage. I'm still not sure how to link and judge what voltages to use, so it's mostly guess work for me in that part.
Anyway, here's a Screenshot just before it gave me a BSOD.
I was using Intel Burn Test to start off with for a quick test, but noticed it wasn't using 100% CPU, so switched to Prime95. 5 mins later I got a BSOD.
My settings in BIOS were:
Multiplier: 24
BLCK: 190
DRAM Freq.: 1440Mhz
CPU Voltage: 1.375
IMC: 1.275
DRAM: 1.5625
CPU PLL: 1.8875
PCH: Auto
Any advice would be great.
I've OC'd to 4.3 and it's stable!
The settings for my stable 4.3Ghz are:
180 x 24
Dram: 1440
CPU Voltage: 1.34375
IMC (Not sure what this is): Auto
DRAM V: 1.5625
CPU PLL (again, not sure if this is QPI Voltage): 1.8875
PCH: Auto
It runs at around 60° in RealTemp at 100% load with a TJMax of 105.
Am I correct in assuming that the i3 550 TJ Max is 72.6 degrees? I set an offset of -23 in Core Temp and I'm running at around 36 degress on full load after 20 hours. I'm not sure which is correct.
Anyway, I want to try to get a stable 4.5 OC now and possibly more, so any help would be greatly appreciated.
I messed with the ratio and multiplier. I've seen people getting around 4.8 on this CPU with an FSB of 200-215. I've not been able to find the voltages I should set though.
The closest I've got so far is 4.5 (Which shown as 4.9 in Windows) but it locked up after 10 mins of Prime95.
i3 550
P7P55D-E
GTX 460
Multiplier: 24
BLCK: 190
DRAM Freq.: 1440Mhz
CPU Voltage: 1.375
IMC: 1.275
DRAM: 1.5625
CPU PLL: 1.8875
PCH: Auto
180 x 24
Dram: 1440
DRAM V: 1.5625
PCH: Auto
