I have a AMD 1GHZ 266 T-bird on an Abit KT7A. I am using a Socket A/370 Bonded Fin CPU Fan with Copper Base made from startech. Here are the specs:
Thermal Resistance 0.68ºC/W
Fan size 50 x 50 x 15 mm
Air Flow 10.9 CFM
Rated Voltage 12 VDC
Rated Current 0.11 Amp
Rated Speed 4700 RPM
Noise 30.5 dBA
Heatsink Dimensions 62 x 52 x 37 mm
Fan + Heatsink weight
Connector 3-lead TX3
Fan Life 54,000 hours
I had to take a fan off a case fan and have it blowing at the CPU just to cool it down more. Without the case fan, I was getting 115F +, but with the case fan, I was getting around 100F +. Which is 50C and rising...I would like to make this go lower. Any suggestions? I am not looking for any water stuff, or anything fancy. A HSF that does cool it down more is what I am looking for. I would like to get this to mid 70F to 80F if possible. My case heat is about 75-80F.
Air Flow 10.9 CFM
Noise 30.5 dBA
