- Dec 11, 2003
- Northeast Ohio
Looking to purchase one of these...
1) NEC/MITSUBISHI DP930SB-BK 19" SuperBright Diamondtron CRT Monitor
2) NEC/MITSUBISHI FE991SB-BK 19" SuperBright Diamondtron CRT Monitor
Which would be best for gaming. Read some post that suggested the FE991SB-BK. Does this perform better than the DP930SB model.
Read also that when you purchase an appature-grille monitor you will see two extremely-fine horizontal lines running across the screen about one quarter of the way both from the top and bottom of the monitor. Saw that these are shadows of horizontal wires that prevent the grille from receiving any transportion shock damage. Furthermore, I understand that any electromagnetic interference with the monitor-or any monitor for that reason-will cause a slight color distoration. Is this usually corrected by a degauss or by simply turning the monitor off? What is the pros/cons of each? Thanks.
