SOLVED Need help on overclocking a DFI K6XV3+ 66
B
Bryan
Guest
I need help mon overclocking my DFI K6XV3+ 33 with a AMD K6-2 500 processor the motherboard has dip switches and i need to figure out how to overclock the front side bus
I think that's one of the boards I used to have and, if I'm not mistaken, I don't think I found a way to get the fsb over 100MHz...
There's really no point anyway, since the K6-2 will not go much higher than 500MHz anyway--unless you have a K6-2+ or want to clock it at 3.5x at 133MHz (466MHz) for the extra bandwith
