Hi folks!
Ive notived that my computer is getting alittle slow.
And I work alot with maya and does some heavy gamings.
My system now is:
P4 Northwood 3.2
Asus P4C800-E Deluxe
Corsair 3200XL 2-2-2-5 2x512mb
SATA Hitachi 160gb 8mb Cache
Excalibur ATI X800XT-PE
DELL 2405FPW TFT
Enermax 460W
Now I need to make this rig alil faster or the more expensive option buy a completly new rig. Thou Im not sure about this cause the new cpus, chips are coming soon and noone knows the performance on them and so on.
So I wounder if I should stick with single core use most of my current stuff and boost it with a small upgrade? and then later when new chips are out and are more worth the performance then buy a new one?
Now what im thinking of upgrading if that is the right call then this:
1gb more memory cause my 1gb runs out fast.
Then my question is should I just buy 2x512mb of exact same type of memory im using now? or is it much better to try sell my 2x512 and get 2x1gb? I dont want to spend to much money on the upgrade.
My second upgrade im thinking of should be a new faster HDD.
Like a raptor 74gb 10krpm as OS and main prog use and keep the old 160gb for storage.
And third upgrade a new cpu as my current northwood is REALLY bad when it comes to OC. I can only run it 100% stable at 212fsb. And yes I know this cant be right everyone will say. But it is. I can push it to 222 but then its not stable. Its a very weak cpu I had bad luck on that one. I tried my friends prescott and it worked 100% stable around 230fsb.
So I was thinking if I try to sell my northy and get a new prescott 3.6 that is pretty cheap now and perhaps OC it to 3.8 rock stable. I would get a pretty nice boost to my old rig? Then my question would be will my asus mobo support the 3.6, 64 bits prescott or the none 64 bits cpu ?
Or ofcourse the last option try to sell my whole rig and buy a new rig Using dual core and ddr2 and 7800GTX pci-e card. But this will cost alot more and Im not sure about buying current duals from intel as new ones will come later in january I think I read ?
Any suggestions would be great.
THanks!
My system now is:
P4 Northwood 3.2
DELL 2405FPW TFT
Enermax 460W
THanks!
