Hi all, new member here. So I weighed the options and decided to upgrade the ol' rig instead of a new build and wanted to start overclocking the cpu. Although I actually haven't even gotten to the overclocking part, I've run into issues with prime95 at baseline.
My current specs are:
MOBO: ASROCK 770icafe (w/ latest BIOS update that supports the AMD FX 8000 series processors)
CPU: AMD FX 8350
GPU: Nvidia GeForce GTX 1070
RAM: 2x8 (16GB) PNY Anarchy 1866 mhz DDR3 (although I'm pretty sure my system reverts to 1600 mhz by default)
PSU: be quiet! Dark Power pro 11 650W
HD: Samsung 850 EVO SSD
I've also got the Corsair h100i v2 liquid cooling system installed.
The system runs very well, I haven't had any issues in everyday use or playing games and the gaming benchmarks are fine but obviously could be better. I began looking into overclocking and downloaded some programs; prime95, CPUZ and hardware monitor. I checked the baseline stats for my system and everything appeared normal, I had the latest drivers and updates for everything. However, running prime95 fails a CPU core immediately whenever I run it. I'm new to this but browsing the forums and googling the issue didn't give me results I felt confident enough to use so I figured I'd ask. Here's the given error message.
So I repeated the test a few times, it's not always worker #6 but most of the time it is. Also in this screenshot the rounding error is huge, it's usually just above 4 like 4.8 or 4.7. Temps are fine, CPU hasn't risen above 41-42 C
Any ideas?
CPU: AMD FX 8350
Any ideas?
