- Jun 19, 2010
Hello,
I have built this system to be my video editing rig, and I need help pushing my PC further to 4.2 GHZ and running stable. Currently I am at the specs below with my PC, however I run prime95 which crashes and at one point a core dropped down to 50% load and failed.
So please look at my specs below and suggest what I need to do further to stabilize a 4.2GHz Overclock on the 980x
Thank you.
Goals: Achieving stable 12GB ram at 1800 MHZ low latencies, CPU to 4.2 GHZ on air.
CMOS:
CPU = Intel i7 980X 32nm
CPUID= 000206C2
Motherboard = Gigabyte X58 UD9 , Revision 1.0
BIOS Version = F5h
CPU Frequency = 4161.13 MHZ
Memory Frequency = 1600.41 MHZ
Total Memory Size = 12288 MB
System Temp = 41C
MCH Temp = 48C
CPU Temp = 35C
Vcore = 1.300V
DRAM Voltage = 1.660V
Ram = 12GB G.Skill Ripjaws 2 Sets of 6 GB (3 x 2 gb)
Ram Info= Newegg.com - G.SKILL Ripjaws Series 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 2000 (PC3 16000) Desktop Memory Model F3-16000CL9T-6GBRH
M.I.T Status:
Turbo Ratio: 24 All Cores
Non-Turbo Ratio: 24 All Cores
CPUID: 000206C2
BCLK: 160 MHZ
Power Management Settings:
ACPI..................................53 (STR)
Soft Off by PWR Button.......4 Sec. Delay
Power on ring....................On
HPET Support.....................Enabled
HPET Mode.........................64-Bit Mode
AC Back Function................Soft Off
ErP Support........................Disabled
Code:
Advanced CPU Features:
CPU Clock Ratio ................................ [25X]
Intel(R) Turbo Boost Tech .................. [Enabled]
CPU Cores Enabled ............................ [All]
CPU Multi Threading .......................... [Enabled]
CPU Enhanced Halt (C1E) ................... [Disabled]
C3/C6/C7 State Support .................... [Disabled]
CPU Thermal Monitor ......................... [Disabled]
CPU EIST Function ............................ [Disabled]
Virtualization Technology ................... [Enabled]
Bi-Directional PROCHOT ..................... [Enabled]
Uncore & QPI Features:
QPI Link Speed .............................. x48 at 7681.87mhz
Uncore Frequency .......................... x20 at 3200mhz
Isonchronous Frequency Support..................[Enabled]
Standard Clock Control:
Base Clock (BCLK) Control ................ [Enabled]
BCLK Frequency (MHz) .....................[160]
PCI Express Frequency (MHz) ........... Auto
Advanced Clock Control:
CPU Clock Drive ..............................[800mV]
PCI Express Clock Drive ................... [900mV]
CPU Clock Skew ............................. [0ps]
IOH Clock Skew ............................. [0ps]
Profile:
Profile DDR Voltage...............1.6V
Profile QPI Voltage.................1.2V
Channel Interleaving...............6 [AUTO]
Rank Interleaving...................4 [AUTO]
Advanced DRAM Features:
Performance Enhance ...................... [Turbo]
Extreme Memory Profile (X.M.P) ......... [Enabled - Profile 1]
System Memory Multiplier (SPD) ........ [10]
DRAM Timing Selectable (SPD) .......... [Quick]
Channel A + B + C
Channel A Timing Settings:
##Channel A Standard Timing Control##
CAS Latency Time ......................8
tRCD .......................................8
tRP .........................................8
tRAS .......................................24
##Channel A Advanced Timing Control##
tRC ........................................47
tRRD .......................................6
tWTR ......................................6
tWR ........................................10
tWTP .......................................22
tWL ........................................8
tRFC .......................................88
tRTP .......................................6
tFAW ......................................30
Command Rate (CMD) ................3
##Channel A Misc Timing Control##
Round Trip Latency ...................58 (On channel C it is at 59)
B2B CAS Delay ..........................Auto
Channel A Turn Around Settings:
Reads: Dimms-6 Ranks-5 On the Same Rank - 1
Writes: Dimms-6 Ranks-66 On the Same Rank - 1
Advanced Voltage Control:
CPU
Load Line Calibration .................[Standard]
CPU Vcore ...............................Current: 1.3000V
QPI/VTT Voltage.......................1.580V
CPU PLL...................................AUTO
MCH/ICH
PCIE......................................1.500V
QPI PLL...................................1.100V
IOH Core..................................1.100V
ICH I/O...................................1.500V
ICH Core.................................1.100V
DRAM
DRAM Voltage......................1.660V
DRAM Termination................0.750V
Ch-A Data VRef. 0.750v [AUTO]
Ch-B Data VRef. 0.750v [AUTO]
Ch-C Data VRef. 0.750v [AUTO]
Ch-A Address VRef. 0.750v [AUTO]
Ch-B Address VRef. 0.750v [AUTO]
Ch-C Address VRef. 0.750v [AUTO]
Case: LIAN LI PC-P80 Mobo: GIGABYTE GA-X58A-UD9 CPU: Intel Core i7-980X 4.00GHz
Heatsink: Lapped Noctua NH-D14 120mm/140mm/120mm - Three fans! Thermal Pad: Indigo Extreme RAM: 12GB of G.SKILL Ripjaws Series 6GB (3 x 2GB) 1600mhz
GPU: EVGA GeForce GTX 480 PSU: SILVERSTONE ST1500 1500W SSD OS/APPS: Crucial RealSSD C300 HDD / GAMES: 600 GB Velociraptor 6 GB/s
HDD: 5 HDD's in Raid 5 for Scratch Disk: 1TB Samsung Spinpoint F3 Blu-ray: Pioneer Black Blu-ray DVD Lightscribe: PLEXTOR 24X DVD/CD
OS: Microsoft Windows 7 Ultimate 64-bit Fan Controller: Sunbeam Rheobus Extreme
Thank you.
CMOS:
CPUID= 000206C2
BIOS Version = F5h
System Temp = 41C
MCH Temp = 48C
CPU Temp = 35C
Vcore = 1.300V
M.I.T Status:
CPUID: 000206C2
BCLK: 160 MHZ
Code:
Profile:
Channel A + B + C
CPU
MCH/ICH
DRAM
