Hello.
I'm thinking of building a custom watercooling loop inside a Define S case. Because my old project with 900D gets postpone, due to its massive size and it barly fits into my car when i'm going to LAN
But the top radiator in the Define S, has a thickness limitation of 55mm for both radiator + fan applies on 420 radiator. And 420 are the Max size of the radiator that can fit in.
Does any of you have an advise on a radiator or any experiance with the Black Ice Nemesis GTS 420 Rad?
