Ok so this morning we were on skype talking to family and my entire rig just shuts down hard. Since the incident I have not been able to get it to reboot. When pushing the power button for a split second a couple of my case fans led's flicker on but the power goes no further and stays off.
First thought was that it was my PSU but I think I have ruled that one out. I disconnected ALL power cables inside and used a paperclip to short the appropriate pins on the main 24 pin mobo connector and voila my power supply powered on and ran continuously including it's fan and led's.
Now although I have proved my PSU runs, this doesn't of course test it under any load but it's only a 2 year old OCZGameXstream 700W so I don't really think now my PSU is the problem since I was able to get it running again.
Once I connect the PSU back to my mobo and leave all the other accessories still unplugged (HD's, Burner,video card etc) it still behaves the same. Won't power on at all, slight flicker of led's, and I just want to clarify the PSU will not turn on at all either.
My mobo displays a Green LED when the PSU is connected and switched on which if I'm not mistaken is supposed to signify that the mobo senses the power source and is ready to boot.
I have also tried removing both ram modules and still no go and I replaced the 3V battery on the mobo too.
So really I am left with the following assumptions:
1 - Even though the PSU can run on it's own, it has a fault now where it will not turn on under load (long shot)
2 - or my mobo has failed somewhere despite it showing a green led that it's ready to go
3- or possibly my CPU itself has failed or shorting out but even in this case, it should still boot up and give the CMOS error that the CPU is missing (like it would if you turned it on without a CPU installed)
Any advice or more troubleshooting tips you guys and gals could provide would be greatly appreciated. Below are my specs
AMD Phenom II X4 940 (cooled by Coolermaster V8 )
ASUS M3A32-MVP
OCZ GameXStream 700W PSU
ATI 5870
4 GB OCZ Reaper's
LG Burner
3 sata HD's
ANTEC 1200 Case
ASUS M3A32-MVP
ATI 5870
4 GB OCZ Reaper's
LG Burner
3 sata HD's
ANTEC 1200 Case
