- May 26, 2004
- Southeast Michigan
Need help using some old W/C parts on new system! Pics added!!
Hi guys,
Well after a long couple years out of the loop, no pun intended LOL, I decided to upgrade to the system in my sig. For now I am considering/debating on watercooling only the CPU or just sticking with good air cooling if the W/C parts I have aren't worth the trouble or waste of time.
Here are the parts I have lying around:
Dangerden Heatercore with shroud
Weapon Heatercore with shroud
They each hold (2) 120mm fans.
The Dangerden heatercore is 2" x 6" x 9.5"
The Weapon heatercore is 2" x 5.75" x 10.75"
Swiftech MCP600 pump
Swiftech MCP650 pump
Probably about 8-10 Sanyo Denki San Ace 120mm fans
Obviously my old waterblock won't work, so I picked up a
Swiftech Apogee GTZ. (only have a couple more days to return it if I decide to go with good air cooling.)
My case is the original CM Stacker.
I would like some comments/suggestions/opinions on what I should do.
Sell everything and start over? Use what I have for now? Just go with good air cooling?
Thanks in advance!!!
Ed
Hi guys,
Ed
