Need help w/ OC Pent III 733
cantrell
Machine is currently very stable @ 825 (150 x 5.5, prime 95 running).... However, I think i could get more out of the CPU..... IF...
Here is the probs... When running higher than 150 FSB ...
@ 151, 152, 153 ... My NIC dies on me.. Are there any out there that you KNOW that will handle higher FSB speeds? Currently using a cheapo LinkSYS
@ 154, 155, 156+, My SCSI UW controller starts freaking out ... Drives only operate in bursts w/ long waits before reading/writing again... ABSOLUTELY kills performance.... Is a Tekram, Do Adaptec's handle higher FSB's better?
@ 157, 158, 160 + Machine will not even bring up the bios menu... I assume that this is a memory fault... If you are curious, it is el cheapo generic PC 100 running @ CAS3 ...
Should I just settle with the 825 or can I do better?
My system
Abit VP6 with twin 733's (core 1.75) have had it as high as 1.90 successfully
Global WIn FOP38 w/ arctic silver compound
3d Prophet 2MX w/ 32 sdram
el cheapo 100 mhz memory 128 meg total
micopolis 9 gig UW SCSI
seagate 4 gig " "
creative ensonique sound
linksys nic
tekram SCSI controller
Any help appreciated...
Can't get to the sound barrier in a Pinto, gonna have to do the unthinkable and get a faster chip... good job so far though.
Pinky
