There are motherboards that have a working bios for FX processors and Win 7 and steam games. Gigabyte boards seem to be a prime offfender with bioses that are not released that fix the Steam + FX processor + M$ issues.
Gigabyte needs to be advised of the board you have with a full part number and revision in order to get a fixed bios.
Below is what it is. Core parking script.
makija21
03-24-2012, 08:46 PM
Yo guys for all who are having Amd Fx ( Bulldozer ) cpu problems i have found a temporary solution try it, if you didn,t get your motherboard bios update like me: The file is in rar, check it with antivirus, I didn,t get any viruses whilst downloading and scanning it!
Rar file: I used it simply, just click the bat file ( black one named: Orochi-CEG ), it will temporary fix some code in cpu, moderators u can check it. Then just run steam and Shogun 2 Total War. I don not guarantee if it will work, but what have you got to loose at this point, maybe it will or will not work.
Ps: Every time you restart or boot you pc, you have to restart this file before clicking play! A temporary solution, don,t kill me! It worked for me! =)
File link:
http://hotfile.com/dl/143814991/eaad23b/Orochi-CEG.zip.html?lang=cz
Orochi-CEG.zip | 1.1 MB Download link 'does' work as I just tested it to see if server still had the file.
