Need help with Memory issues
cayla
Picture of memory bank and questions:
LL
for b) The CPU should use address 101100 to store A in chip 2 with the location 22. My thought process is that the first bit decides which ram chips will be used. When the first bit is 0 we use ram chips 1 and 2 etc( because of decoder). The other part (10110) will be the location of the letter.
So am I correct or totally wrong?
for c)
If I used 101100 as the address for A then wouldn't B be stored at ram chip 1( since B is stored within data lines d0 - d7) with the same address 1011?
I am on the right track?
trents
Senior Member
Are you asking this as an academic issue or do you have a real problem we can help you troubleshoot?
