Need Help With Missing Files
setotitan
hey guys need some help here. the other day i was noticing i couldn't find MS paint, i even opened the run window and typed "paint" and no luck. i tried to do "calc" for the MS calculator, just to make sure i wasn't loosing my mind, and got an sys error. i brushed it aside because i've got other apps that can handle those functions. but then again tonight i ran into an issue where i couldn't get to the speaker icon in my sys tray to control my volume. i was informed to check in windows/system32 for "sndvol32.exe" and turns out it was missing as well :screwy: so anyways i don't know if it was a virus or what but i seem to have lost a grouping of sys exe files. not sure exactly what folder but it's in "Accessories". i see the "Accessibility, Communication, Entertainment, and System Tools". funny i've never bothered to notice what files where in that grouping. anyways i'm looking for a way to get those programs back. is there a repair utility or some way i could extract them from the windows install disk? i'm running XP Pro 32bit if that helps. any input is welcome!
redduc900
Inactive Moderator
Portland, OR
Are the Accessories still listed in Control Panel--> Add or Remove Programs--> Add/Remove Windows Components?
setotitan
setotitan
sorry it took so long to respond, however no i don't see "Accessories" in "Add or Remove Programs". so what's that mean?
setotitan
setotitan
oops.. must have been half asleep when i read your first post. i was looking in the list of progs for it, didn't even see it was a button on the left. found it and the option to reinstall "Accessories" thanks for the help.
