Hello Overclockers,
I'll start by listing my spec:
i5 4690K 3.5Ghz
GTX 970
8GB RAM
MSI z97 Gaming 5
Cooler Master Hyper 212
2 x 250 GB Samsung SSD (RAID 0)
I've been researching OC'ing for a few days trying to understand as much as possible before I gave it a shot, but it seems I am either doing something wrong or have misunderstood, or both... I started out by setting my disabling turbo boost, setting multiplier to 42 and my core voltage to 1.2... this ran Windows and was stable with stress tests (temps avg 60) so I thought I would try to bump it up a bit to 4.5 and 1.28V, this caused instant blackout and I needed to remove MB battery in order to reset BIOS. So I went back to 4.2 Ghz and tried to find a lower voltage starting at 1.15V and then moving down to a point where it didn't work and then bumped it back up a bit... This point was around 1.13V, but on running stress tests, I got 'there is a problem with your PC and needs to restart
'... so then I started incrementing the voltage back up and got to 1.15V which was stable running stress tests for over an hour.... I then decided to play BF4 which I can run with ease, and after about 30 mins, 'problem with your PC
'... Im now at 1.16V and 4.0 Ghz running a AIDA64 stress (CPU, FPU, Cache, Memory, Local Disks and GPU) test with all cores averaging below 60C max below 65C.... I don't know whether Im doing the right thing increasing the voltage and lowering the multiplier... I need some advice please!!!
Any replies I thank in advance.
P.S I have files saved of my statistics for a few OCs I tried, Never once did my temps go over 70 and it seems like my CPU is not in a danger zone but I can't get it to be stable.
EDIT: Now running at 4.5Ghz, with 1.35V... this is higher voltage than I wanted to go too but all my temps on AIDA64 are maxing around 80 and averaging about 70. Seeming to be stable after 30 mins of testing.
i5 4690K 3.5Ghz
GTX 970
8GB RAM
MSI z97 Gaming 5
